I've had my case xt40 for about a year and a half now, it's got 3200 hours. I put about 500 hours on it. Anyway, ever time I dig in the dirt with it for more than an hour the high temp warning light comes on and some times the high oil temp light will follow. If I stop and wait a few minutes it goes off and your good for an other 1/2 hour.
I've cleaned the radiator and oil cooler, fan is working fine.....??? Last winter I added coolant to give it a higher freeze point, and it was fine until this summer. Think I'm going to put it back to a straight 50/50, not sure why it would get hot. Water pump? It's not leaking or making noise and thermostats are usually either good or bad. It's never actually over heated, however the light coming on has got to be fixed. The digging I was doing is in straight sand and I wasn't over working the machine. It should of handled it just fine.
Any ideas or thoughts would be greatly appreciated.
