Yamahog.pop
I have a Melroe Bobcat M-700, era about 1967, It has a VH4D (S/N: 4558985, Spec 311711) Not the original motor. (if anyone could tell me the date of the motor that would be great) bought it about 4 - 5 yrs ago, was kinda a mess, cleaned it up, redid all wiring, new coil, plugs, wires, seem to run well, but 2 winters ago it decided it was only going to start hard & run short times, acted like not getting fuel. Last summer replaced mechanical fuel pump with electric, got it to start and run, still not steady, rebuilt carb, no improvement, replaced carb, installed fuel line filters, same issue, could occasionally get to stay running bit longer when choked (before new carb, now makes no diff). Did seem to note that she seemed happier with a full tank as apposed to 1/2 tank, but couldn't swear by it. To date: I have pumped all fuel out of the tank, replaced the fuel cap, replaced & re-gapped plugs, new coil, (but did note new coil gets warmer than old one), fresh gas, new fuel line from tank, The unit has Electronic ignition (Pentex I assume), far as I can tell, still acts like someone shut off the gas or flipped a switch, but have a glass filter in line, can see it is full, (by the way, this is the 3rd fuel pump I have tried, all low pressure).
These items I have not replaced: the plug wires, nor the coil to dist wire, Cap/Rotor, Pentex ignition, The unit is positive ground, thus I had the old coil reversed, put on new coil, ran for while, began start stop pattern. (I did reverse the wires on the coil in case it was a polarity issue, same OH same OH!) The unit starts almost immediately after stalling, under 5 seconds, 10 at most, usually without choking. So if it is the ignition module, wouldn't it fail and need to cool down before any future success, or start hard? The only other thing I have just now considered is the air filter possibly plugging, not sure how, is older with oil bath, sorta? But wouldn't that cause choking like running, seems to run clear, no smoke, is a bit hesitant to rev, but once she has her wind, watch out! There is a relay and some sort of wiring/condenser (???) mounted on the engine, I believe these go to the onboard generator, but the unit has an external alternator, I did hook them up, mainly because they were there. It ran with the wiring as I had redone it, and ran good, now this, am stumped. I thinking it might be related to the Electronic ignition, but how do you tell if one is going bad, and would they restart almost immediately? I would think if it was the ignition, it wouldn't be willing to restart so fast.
AT times it's like someone turned off a switch or stopped the fuel: do these things have low oil sensors that might be killing it? (Oil level is good.) Thing uses an idiot light for the oil warning. The other thing that occurs is that maybe (and I felt this way with the old carb) the needle valve was not letting in fuel fast enough, but shouldn't this have been resolved with a new carb, and there are two filters on the fuel line, should be clean. this could explain the ease of restart, since the pump keeps pumping after the stall, which would refill the carb, all lines from the tank to the pump, and pump to carb are new. I am using a lower pressure fuel pump, everything I could find motioned that way. (to drain the tank, I used the electric pump, pumped until dry, not a hiccup)
It does not slow or slug down, simply acts like out of gas or ignition switch was turned off. What do Pentexes act like if/when they go bad?
Any other ideas, I am open for suggestions. I don't work on this every day, but have a couple of projects I need it for, would like to get finished sooner than later. I have included some pics of the unit, anyone see anything that stands out? Could this be related to a bad, failing, or corroded ignition switch? (did have wasps build in the gauge/ignition box, but got that cleared out and sealed) but why restart so easily? Am grasping at straws, literally!
Thanks for your time!!
