I've got a GL422, nice laser in its price range, not my favorite one, but good enough for most jobs, I mainly use it for survey work and simple jobs that don't require high accuracy. The only complaint I have with it so far is you can't charge it off of 110, only 12 volt, which to me is a pain to deal with, I charge everything in the house overnight where its always warm and I can monitor if they are charged or not. That laser also won't take a charge if its cold, it has to be warm enough BEFORE it'll charge, which means I have to take it into the shop in cold weather, let it warm up a few hours and then go back out and start to charge it.
It has a remote, which isn't a long distance remote, but helps somewhat, it also has shutter shut down, which is really nice for others who work the same area I'm using it, we just shut off the three sides I'm not using or needing, that can also be done from the remote.
Its not the top of the line spectra, but good enough for most things, I basically got mine for a back up laser if my other one's go down and need repair.
