hetkind
All you really have to do is raise the wages and status of the mechanics to get folks back into the field.
For what it's worth, I never knew how bad being a mechanic could be until I started working part time at a used car dealer my last year of college. That's when I learned about "Mitchell" and the flat rate system. I couldn't believe that someone had boiled down almost every possible repair on almost every possible vehicle to a "by the book" procedure. It didn't matter if all bolts broke off in the block when you tried to change a water pump, if the book said 1.5 hours, you got paid for 1.5 hours.
This sounds like a good theory but it has failed miserably in my region.All you really have to do is raise the wages and status of the mechanics to get folks back into the field.
Wes J.
I am at the end of my career, only have a few more years left and then I will close up my tool box and fade away and let the next generation of mechanics take over.
Some of the old guys that I worked with years ago had time on steam engines. I wonder what they would think if they saw these new DD16 engines we run in our trucks now. Hard to even tell it is an engine with all the plastic and wires on it.
I'm currently on an advisory committee at our local tech school where they're starting a heavy equipment tech program. And the more we've studied the issue the more complicated it gets.
However, it always seems to come back to the same issues.
- society in general has pushed for college and white collar jobs, which is fine but obviously not everyone can do that.
- Many corporate run companies have turned employees into "numbers" and squashed employees desire to excel or take pride in what they do. Along with hiring "educated" upper management as leaders that end up causing even more division.
- pride in what you do and desire to produce quality has taken a back seat to the bottom line.
Good pay is a must but good working environment, good equipment, good benefits, AND rewards for quality work is a good start.
They changed the hours of service to supposedly make it safer but in truth the industry got a better deal than the drivers.
the driver shortage the government just brings in more foreigners and give them cdls that's what there fdoing around here
Doing Fleet repair on "Long Trucks"is very Hard Work. ....Low Pay and you're treated like dirt. But Great pay for drivers and they Kiss their Arses.
To do Fleet work in the USA most companies require a CDL ( to pull the truck in the door )
So if you have your CDL Why buy all those tools and sign up for abuse and Half the yearly pay a (foreign? ) driver makes?
Have you worked as an over the road truck driver? Many of these outfit expect you to drive 11 hours every day and stay out on the road up to 3 weeks at a time. Experienced owner operators can usually work out a schedule to get home every weekend, but the cost to play at that level is much more than the average mechanic puts into his tools.
The best thing that the US could do about the driver shortage is increase the max gross weight drivers can haul. Even if that comes with higher standards for testing or costs for registration, it would certainly save money. There is no reason that Michigan can allow 165,000 lbs gross or Washington lets you pull 120,000 lbs on a super B but everyone else is stuck with 5 axles and 80,000 lbs.
