Holy What
If someone sent me to do a shift on one of them huge boxes with Akerman written on it I would probably say 'Holy S**t!!
Only joking, they certainly earned their reputation as the toughest old girls around, unfortunately I never got to try a wheeled version but have witnessed one dispatching tippers for fun on a muckshift at a rate most tracked 20 tonner drivers would only dream of.
As for blade uses, Rob is right that only the imagination of the operator sets the limit.
The obvious ones are cleaning up without virtually a trace, moving steel plates, steadying pipes or other long objects or moving roll on skips at an alarming pace!!
Of course anyone who has ever laid ductile water main will confirm that the blade is actually a vice attachment to hold bends whilst you push pipe in with the bucket.
The other item no 'Duck' should be without is the TAB or Two Piece Boom, this item can really make the difference in skilled hands.
I have used them on several Ducks and can say with all honesty I would pay the extra to have one.
They make lifting far simpler and safer, aid when working close in on verges and make you look a real pro when digging deep square holes.
There is one other point about Ducks that others may confirm, the fact that they will out lift their tracked counterpart by significant amounts.
I obviously don't want to advocate lifting items in excess of legal limits, but when called upon I have lifted and placed some weights with Ducks that other tracked counterparts could not loook at.
A komatsu pw130es I used for around 18 months used to run Cat315 buckets on a Miller hitch to be compatible with the tracked machines.
These were a large bucket for the machine, but it handled it with ease.
However on one sewer job I had to unload steel frames from a lorry and the weight on the ticket was 5300kg. The Komatsu lifted and carried these much to my amazement even without a two piece boom, try that with a pc130 and I think they would still be on the truck.
