Blue Tops
In the old days ;
Blue tops, were Blue keel stone, or chalk on 1 1/2" square wooden pegs 6",8", 10" long. They were set in the sub base, with a bull ***** and sledge pounding a hole opening 1st. Then pounded in with a 4# hammer, to exact grade. Then Guard Stakes were put in alongside, to show location. This is where the "Stake Hopper" came into being.
Nowadays, they are set, painted blue and blue whiskers mounted on the edge, parallel to the travel direction, so the whiskers, don't bend over the top of the hub, get pinched and pulled out. They bend over in the crush alongside the hub.
Blue tops are for the finish course,(Crush aggregate/D-1) Asphalt goes on top. Blue whiskers used here.
Red Tops are for the sub base course, (-2", or whatever classified specs called for) Pink whiskers used here. Pink shows up better than red.
I carry a contrasting color, yellow whiskers usually, when one hub or whisker is pulled out, my stake hop, puts a yellow one back on, so the surveyor can verify it's accuracy later.
The hubs and whiskers come in varying lengths, depending upon material where used, and accuracy(weak shoulders) of previous lift, and thickness of lift desired.
Now with the new grader mounted, computer blade controls, it becomes another ball game. Less wood.
