White Excavating
Need help with my wet line on lowboy tractor. Went through extensive rebuild of truck and replaced lines for wet line during this now it will not work. Changed over to a side saddle hydraulic tank with a 1 1/4 line run to the inlet marked on pump. I ran one line up to coupler off of the port marked cyl. The other coupler I ran directly to tank. The pto engages but pump will not build pressure. Does not wine like it out of fluid. I can run pump for 2 mins till I feel some heat start to build. Never let it get hot. Seems like a air lock. Tried to pressure tank to force fluid into pump nothing..
