In reply to John C. The recommendation is for 11018 on all large ripper shanks (D8 & up). Wire feeders mean that you don't have discontinuities within the length of the groove caused by stopping to change rods. Also you don't need an all-position wire because you have the shank laid flat so you can deposit even more metal per minute.
We used to install run-out tabs (often a piece of structural steel angle heated and formed to the same angle as the groove on both ends so that you could establish the arc and stop the weld actually outside the area of the repair weld and then remove them afterwards with a cutoff wheel.
Bigway, Not so much the hard surfacing per se, but you have to make sure that the hard surfacing does not introduce stress risers into the shank. That WILL cause it to fail, the root cause being the way the HS was applied, not the HS itself. Pre-heat and cool as per the recommendations in the document I sent to you, and keep the hard surfacing away from corners if you can avoid it.
