Vin location on Case 1450 Dozer
blue66tang
West Coast
Hi guys, my vin plate is gone on my Case 1450 dozer, and I need to get some parts for it. Is there another location stamped into the frame somewhere? Very frustrated!
alrman
QLD Australia
Remove the engine covers & look at the chassis rail. I recall the LHS .... maybe.....:rolleyes:
blue66tang
West Coast
Hmm I did that, but its so dirty and hard to see in there that it would be nearly impossible to locate. I am looking for a more specific location. I called two different case dealers and they were about useless. Ill try looking closer but i doubt ill see anything.
blue66tang
West Coast
Do you have a 1450 as well? If so, have any idea where to get a good inflame kit. I just pulled mine apart and it had two broken rings and the back liner running water into the pan. I really need to find the vin number to find out exactly what i have.
Anybody have any suggestions where to get good inframe kits?
alrman
QLD Australia
No @blue66tang I don't own any machinery, I make a living out of repairing it.
The 1450/B should have the Case 504BDT engine. Look closely at one of the valve rocker covers for a decal with tune up specs.
Doesn't the engine have a model / serial number tag either?
I can't recommend a supplier due to my location. Google is your friend ;)
blue66tang
West Coast
Found it, was under a bunch of grime. Had to do an inflame so I spent quite a bit of time under it cleaning and finally found it.
Anybody on here know of a parts machine?
