Elmeche
Hi,
I search an info for the truck system remote control of Hetronic G610.
If someone has even pictures of internal compartment and / or wiring of the sender, also it will be good of the receiver too, please post here or send to my e-mail.
The the initial error was regularly fall of connection, the customer send both controls to some "technicians" where there cut all existing wiring, removed all connectors from the coder board of the sender, similar happen to base receiver in effort to made own remote connection and boards - and failed!
First big problem is that they didn't make the photos, schemes, sketches and now I have to investigate all.
The second is that I have significant success in this undertaking - establish communication; can send emergency state correct; one relay-K2 can control on/off, but have troubles with other commands.
Any information will be in great help! Thanks!
The first picture - of receiver/ base station is the most similar to original except one additional board in my set.
The second is bare coder board - I repair it completely except in my opinion there have to be some big SMD resistor in bottom left corner or tru hole resistor, or some cylindrical fuse. I don't know where the corresponding pin led to assumption rightly.
