sawmilleng
I've got an older Kenworth single axle cabover that spent nearly all of its life as a picker truck with an 8-ton crane mounted just behind the cab. The crane has been removed and I want to use it as a farm flatdeck/dump truck.
The frame is cracked right around where the picker was bolted onto the frame. It isn't broken completely but needs repair.
I've heard that some frames can be welded and some can't, due to heat treated frames and the like. I don't think this little KW frame is heat treated--at least I can't find any warnings on the frame about "no hot working"!!
I am also confused about whether frame welding is allowed in my area--BC, Canada. I have heard that some jurisdictions don't allow frame welding, PERIOD but I hope this is just BS.
Can anyone tell me what is required to do a repair that would be accepted at a vehicle inspection? Does it have to be documented that a ticketed welder did the job, at the correct phase of the moon and used the right brand of bubble gum welding rod, dipped in water just right, to seagull-shzt the crack together? :tong
Your comments and suggestions would be appreciated!
Thanks,
Jon.
Thanks,
Jon.
