STOP trying to maintain the old systems on TMZ34 unit. It will cost you more money in the long run (new boards and membrane pads every year) than just updating to the retrofit kit. (also, getting replacement boards for these units are getting harder and harder to get)
Contents of Kit 104867
For use on models with manual outriggers
from serial number T3498-001 to T3499-769.
Contents of Kit 104866
from serial number T3400-001.
Contents of Kit 104855
For use on all models with hydraulic outriggers.
This kit will replace the circuit boards with relays, diodes and, resistors. and the membrane pads with actual push buttons. (No more angry pixies trapped inside F.M boxes) I've attached the install instructions to give you an idea of what your infor.
Link to my older post:
https://www.heavyequipmentforums.com/threads/genie-tmz34-19-sert340069.55581/#post-715997
