TimT
I have had two E27B New Holland "Kobelco" Mini's. I installed the Thumbs on both the old mchine and my new one. They are USA attachment thumbs. On the first machine, I put a gauge on the Auxiliary valve lines used for "Nibbler/Breaker" attachments, and adjusted the Aux valve block relief pressure to 3,000 lbs... the rating of the cylinder. The instructions say to lower the Aux valve pressure to 80% of the thumb cylinder rating. I adjusted the valve so the thumb would just barely push the bucket back.
On my new machine, the valve for the Auxillary is a variable flow valve with a toggle instead of a full flow push button style. I never bothered to lower the pressures on anything. The piston rod on the thumb is bigger than my bucket cylinder rod and it WILL push the bucket back if I'm not careful with it. I figure that the relief opens on the bucket cylinder circuit and will hurt nothing if I don't make a habit of it. The system relief pressure of the E27B is 3336 psi. I am I asking for trouble?... I have not broken anything yet and have used it quite a bit. I was reading a thread here about having to install all kinds of external relief valves etc on a Kubota machine. I had a guy that should know tell me that unless I relay pound the thumb into the bucket all the time it should be fine, he said those small machines can't relay blow a thumb apart. I realy like having the variable control so I can squeeze right to the point of pushing the bucket back. What do you think?
