willie59
Here's another application of the suck bucket. I learned a long time ago, as a field mechanic, to try to control/contain my messes. First of all, property owners aren't too keen to find a big oil puddle on their ground. Second, the enviro implications can't get serious now days, don't need someone knocking on my door. But during this time, I've found I don't like to necessarily work in a mess anyway. So, what to do when you have to crack open a hyd line and don't have room to get a catch pan under it. Solution? The suck bucket. :tong
What we have here is a Kobelco SK480LC with a cracked seal boot at the center rotary joint. This has allowed rain water, and a lot of it, to get into the slew gear housing under the turntable, not good. If enough rain water is allowed to get in there, it will get into the slew ring bearing, very not good.
I don't have to remove the big lines in the center, can uncouple them from the flange connections where the hoses connects to pipes. But that large hose on the side, and the high drive pilot line on opposite side, I have to take them loose and remove the fittings to fit new seal boot. Now that's a good size line on the side, acutally the case drain line for the drive motors. I took it loose at the topside so it wouldn't siphon from tank, but when I pop that fitting loose, it's going to dump some oil. You know, that thing that if you spill a quart of oil on the floor...it actually looks like a gallon! LoL. Can't get any kind of pan under it to catch the oil, so grab the suck bucket. Place the vacuum tube from suck bucket under the fitting, and crack it open, suck up the oil as it drains out.
I was in an awkward position, so kinda fumbled the hose fitting when it came loose, spread a little oil. No problem, work the vacuum tube around and suck it up!
Once I got the old seal boot off, I emptied the oil from the suck bucket, and proceeded to draw out the water that had collected in the slew gear housing. Pulled about 8 gallons of water out of it in a short time. Hey...beats the heck out of removing that little drain hole plate under the rig and getting drowned in swamp water! Ha!
I've even built a little reservoir dam with clay oil dry around an area that a hose is being removed, sucked the oil out of the reservoir, then when finished, used the suck bucket hose to suck up the oily clay oil dry bits.
