thepumpguysc
- Joined
- Mar 18, 2010
- Messages
- 7,535
- Location
- Sunny South Carolina
- Occupation
- Master Inj.Pump rebuilder
I went to look at a fuel leak on a BIG JLG fork lift {after hrs} the other nite..
Leaking throttle shaft.. no biggie, seen it thousand x before..
You have to pull the engine half apart to get to it tho.. I'm up for it..
get it apart, take the cover home, ream the housing, put a new bushing in it & let the epoxy sit over nite..
Head to the jobsite after work.. put new orings on the shaft & install the shaft.. NOPE..
They bent the shaft so bad that it wouldn't go back in the cover..!!!
I tried for 30 minutes.. & gave up..
I showed the on-call mechanic & he said.. "yeah, I found that if I tightened up on the throttle cable, it would cock the throttle & slow down the leak"... WTF???
I mean, REALLY?? I just shook my head & said, "I'll be back tomorrow w/ a new shaft"..
In 30+ YEARS of doing this.. I've NEVER SEEN THAT.. & I've worked on some crappy machines!!!
WHY wont people tell you the FULL STORY?? Your there to HELP THEM..
I guess they think, if you leave out certain details, it'll save'um money?? I don't get it..
NOW, its another service call charge.. another wasted evening & the rain is moving in for a solid week..
