first try to calibrate the angle sensor per the Service manual (p/n 1268556 pag 51) link :
http://manuals.gogenielift.com/Parts And Service Manuals/data/Service/Z Booms/1268556.pdf
- you can not test the internals of the primary boom angle sensor (p/n 88149GT) BUT you can check power and ground! Go to the second to last page of the service manual grid N/O-13
- test and inspect the J20 18/19 harness running up the the angle sensor
-Grounds: Pin 3,7,11 all tie into the lower control box "P2" connector pin 25 (P2-25)with the harness disconnected from the angle sensor. Ohms out each wire to P2-25. should be =/< 1.0Ω on each wire.
-Power: plug everything back in. power on the unit and the key to service bypass (you should now have power on your P11 circuit) Using BATTERY negative for your ground (Not the other pins in the plug or the chassis) check for 12v on pin 8 at the angle sensor
-If the harness checks out and you have good power / ground to the sensor and the unit will not take calibration, than replace the sensor (p/n 88149GT)
