Deas Plant
Rollers are NOT boring.
Hi, Digger242J.
Again, it's your attitude that governs whether the job is boring or not. You can have a LOT of FUN with a roller, especially a smooth-drum following a grader. With a little knowledge and undertsanding, you can annoy the hell out of the grader operator by rolling his crown sideways. You can even do it to opposites sides in alternate sections so that the crown has a 'staggered' appearance. This will usually cause steam to issue from the grader operator's favourite ears, giving the grader the appearance of being steam-powered. Then you take photos of the said steam-powered grader and post them here on HEF.
Another little trick for a roller operator is to get right up behind the grader as he is finishing his pass. He throws the grader into reverse and begins backing up, only to run smack into the front of the roller. That usually gets their attention focussed on where they are going when reversing, which makes for improved safety on the job. It may also make for a steam-powered grader and more photos on HEF.
Or, you can roll his dumped road base or fill BEFORE he gets to spread it. This will often cause the grader operator to make like a demented windmill with copious quantities of unprintable verbage directed towards the offending roller operator. Rolling the windrows is usually good for a blast too.
Hey, Grader4me, Randy and Northart, how am I doing so far? LOL.
Mind you, it has been said before and may well be said again that smooth-drum rollers are only kept on the job to fix grader operator's mistakes. LOL.
Hi, Digger242J.
