gary808
hey i have a tampo 10 ton single drum roller from the early 70s ( x military unit )
it had sunstrand pumps on it ,the system is filled with atf and it has no hydraulic power at all ..?? should it run something like 10wt trans fluid ?
our 12 ton bomag calls for 10wt hydraulic trans fluid.
the machine has under 300 hours and has a new viberator pump ,but the whole system is running really slugish .
we have been through the whole system everything is clean and in working order so were thinking maybe the atf is two thin for this machine ? being a older machine im not sure if they designed it to run on a heavyer oil.
and input would be much apperciated .
