I realize this is an old post but maybe can clear some things up and save people some money. 7018 should be fine but what machine are you talking about? 7018 is the recommended rod for welding ice lugs to pads or welding new grousers on so welding the pads to the links shouldn't be a problem. Use a couple hundred deg's preheat if you want but if you put say a 4" weld on the outside of the rails on both sides, the pad isn't going anywhere. It's not like it's a brand new undercarriage you're trying to save. Why spend a fortune on stainless rods if you don't need to. I welded a master link and pad up with 7018 because the bolt holes were stripped and it help for a few years till I replaced the undercarriage. Rails used to rebuilt by welding as well which also indicates you don't need exotic rods to weld on pads or rails. Any rod with the second last number a 1 is all position whether it's 6010, 6013, 7014, 7018, 8018, 9018, 10018, 11018 or 12018 etc., etc. If it's number 2 is for flat and horizontal. MIG (ER70S-6) could work too but run it hot and preheat for sure. MIG cools faster so preheat is more important.
