Suitable substitute for Bobcat "hydrostatic" fluid??
Discussion in 'Skid Steers' started by special tool, Jul 11, 2009.
  1. special tool
    special tool Senior Member
    Jun 15, 2008
    878
    Bethel, Ct.
    Anything suitable for a Bobcat in a pinch when the Bobcat dealer is closed for the weekend?
  2. toomacho
    toomacho Well-Known Member
    Mar 17, 2009
    114
    High School Teacher
    Dawsonville GA
    I use Costal hydraulic fluid that I get from the local auto parts store. It is suitable for tractors as well and has never caused me a problem.
  3. mouse
    mouse Well-Known Member
    Jul 27, 2008
    166
    (wishfully) avoiding work as much as possible
    Sydney, Australia
    the owners manual for my '04 s185 says to use the engine oil of 15w-40 grade.
    the later model manuals for some of my other bobcats don't suggest using motor oil... but then they don't suggest anything except the bobcat fluid.
    now as far as i know, bobcat components and systems haven't changed much in the last 5 years...
  4. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,588
    Service Manager
    Knoxville TN
    I think it's a preferrence thing. I've seen guys that will use only OEM oil in their machines, and I'm ok with that. On the other hand, there are other quality oils out there that are suitable. After all, there's nothing unusual about the Bobcat hydraulic system, they use the same type of hyd components that are used thoughout the hyd world. IMHO, a good quality AW hyd oil will work fine. I prefer AW oil as opposed to RO hyd oil. RO oil has additives to inhibit formation of Rust and Oxidation. AW has these additives as well but also has Anti Wear additives, and doesn't cost much more. The debate is usually which grade to use, 32, 46, or 64. I'm going to climb out on the debate limb and say AW32. Some will say you need 46 or 64 to deal with heat, but the Bobcat has a pretty good oil cooler to control heat, so I think the AW32 will work just fine along with the oil cooler and give good cold weather performance.
    My 2 :)
  5. Cal Blacksmith
    Cal Blacksmith Member
    Jun 1, 2009
    24
    Riverside Ca
    When I bought my 763F I talked to the bobcat mechanic and asked about engine oil for oil changes. I told him that I was using Delo400 and he said that was a good oil and I could use it anywhere on the machine that need oil, including the hyd system. I took his advice and have not had a problem in the 6 years that I have owned the machine.
  6. special tool
    Jun 15, 2008
    878
    Bethel, Ct.
    Hey thanks for all the info, guys.
    I put some 32 in there and made my wife happy over the weekend....can't ask for much more than that.;)
  7. Ryanrb25
    Ryanrb25 Well-Known Member
    Jul 16, 2009
    146
    In all 12 bobcat machines we use, We use 15w 40 ELF Diesel Engine oil in both the Engine and the hydraulics. They range from s185, s250, s300 and 435 excavators.
