Skip Loaders.......
Discussion in 'Other Construction/Demolition Equipment' started by 9420pullpan, Feb 27, 2006.
  1. 9420pullpan
    9420pullpan Senior Member
    May 5, 2005
    1,162
    Central PA
    anyone have any time on these skip loaders. from what i hear they are very useful.
  2. Dozerboy
    Dozerboy Senior Member
    Jan 18, 2006
    2,184
    Operator
    TX
    I have spent more time on them then I ever wanted to your back will never be so sore again. JD IMO is the best, but I have heard Cat has a nice setup too. I ran a few old Fords, and you want to talk about tedious work, modern skid steers would kill and old Ford in production.
  3. Bob Horrell
    Bob Horrell Charter Member
    Nov 18, 2003
    424
    Owner/Operator grading business
    Acton, CA
    I spend a good bit of time on a John Deere skiploader, sometimes looking backwards all day long. You get a real good case of "tractor neck" from turning around all day. I found a beer when I get home goes a long way toward taking the kinks out of my neck.
    I have a device similar to the red one on the back of the second skiploader except it has higher side plates and the blades in it are on an angle and are controlled with a hydraulic cylinder. It beats the heck out of a rear gannon on roads or any large flat surface. I specialize in finish grading and it has made me a lot of money. I have it so I can pull it behind the skiploader or push it in front of my skidsteer. On a washboard road the angle blades cut off the tops of the washboard much better than a gannon. It is 7 feet wide and 5 feet long. A very useful tool for many finish grading jobs.
  4. RyanCKing
    RyanCKing Active Member
    Jan 31, 2006
    31
    Central Valley , CA
    I saw a Cat skip loader the other day anybody know if these have always been available or if it is something new? It looked like it had the same tractor as the 420Ds.
  5. Jeff D.
    Jeff D. Senior Member
    Nov 9, 2005
    1,280
    MN.
    Forgive my ignorance,but what is the term "skiploader" referring too??
    I've looked at the picture again and again,and what I see is a industrial tractor,with a front end loader and a three point hitch.A TLB without the B.
    Is that a skiploader,or is there something in particular that makes this different than what I described??Something special about the loader,maybe??
    Someone said there's no dumb questions.
  6. digger242j
    digger242j Administrator
    Oct 31, 2003
    5,889
    Self employed excavator
    Southwestern PA
    We always have so far, haven't we? :)
    I also am not really conversant with the term "skiploader". I'd heard the term, but I'd always thought it was someone's garbled pronunciation of skidloader. I guess I was mistaken.
    I've seen similar machines used on pavement milling jobs, but they've been equipped with angling backblades, rather than just those boxes. They use a couple of them to clean up the crumbs that the milling machine fails to get onto its conveyor.
    We learn something new every day...
  7. Jeff D.
    Nov 9, 2005
    1,280
    MN.
    If a skiploader is simply a tractor/loader with a three point,I could see how it would be very versitile.Especially for people like me who use equipment for work,and home.
    I've a 6ft snowblower for the Farmall that would fit perfectly on the back of that,providing there's a PTO.
    In some regards I like a loader like that more than a skidsteer.They may not be as manuveable,or efficient,but I'd feel more comfortable loading a truck with it,over a skidsteer.Just because of the added wheelbase,and the fact there's not dirt raining down on the cab when you lift it up that high.Also a more stable feel on uneven ground.
    But maybe's there's more to the term than that?? :beatsme
  8. Orchard Ex
    Orchard Ex Super Moderator
    Jul 7, 2005
    1,051
    Southern MD
    I had always assumed that it was referring to the European "skip" or container that gets dropped of on a building site - like a "swap-loader" here. The skip loader is either the truck that picks it up or the loader that fills it.
    Maybe I'm mistaken too?
  9. RyanCKing
    Jan 31, 2006
    31
    Central Valley , CA
    I’ve always have heard skip loaders are a western deal. From what I have heard it is a relatively small market. They are very abundant in California.
    The John Deere 210 LE and Case and the Case570m are good example of the newest skip loaders. They are basically a backhoe loader with a 3pt or even just a counter weight.
    They are much less expensive than a wheel loader while still maintaining good truck loading characteristics.
  10. Bob Horrell
    Nov 18, 2003
    424
    Acton, CA
    What I have always found odd about skiploaders is that the max loading height is only around 9 to 9 and a half feet - much shorter than front end loaders. It is also much shorter than my S250 bobcat which is 10 and a half feet. Of course this holds true for the standard sized TLB as well.
  11. Squizzy246B
    Squizzy246B Administrator
    Sep 9, 2005
    3,388
    Digger Driver
    Perth, Western Australia
    Hello Bob, Any chance of some photos of your box leveller??
  12. farmerted44
    farmerted44 Well-Known Member
    Nov 17, 2005
    184
    heavy equipment operator
    Arizona
    skiploaders real common here in the desert..used extensively in residential construction. grading house pads, landscaping ect. ect.
    oh by the way we got rain alot today over 140 days with none.:notworthy
  13. RyanCKing
    Jan 31, 2006
    31
    Central Valley , CA
    Bob or Farmerted
    Have either of you ever seen a Cat skip loader?
  14. CascadeScaper
    CascadeScaper Senior Member
    Feb 28, 2005
    1,162
    2nd year Operating Engineer Apprentice
    Lynnwood, WA
    I saw a new(er) Case skiploader the other day. Nice looking machine. I think it was an M series. I've seen quite a few over in the Seattle area, although I'd probably never own one.
  15. hillrancher
    hillrancher Active Member
    Feb 3, 2006
    25
    owner
    Eureka Springs, Ar
    skip loaders
    This is where I think they got their name Do you remember the old cement mixers before ready-mix plants that were pull around to the job site and mixed the concrete on site. they were small to 6yds or. These had a skip that you put gravel, sand and ect in then was winched up by a cable into the mixer. They called the small loader a skip loader that loaded the skip.
    There is a cat old just north of me looks like an old D4 pony start with a loader on it runs straight up a mask and the bucket trips and drops the load. The loader frame has a tag that reads caterpillar skip-loader.
    My opinion not in stone.
    DC
  16. xkvator
    xkvator Well-Known Member
    Apr 10, 2005
    243
    pa.
    That is what I thought of as a skip loader...kinda like the skip cars that feed ore to the blast furnace.
    But...They seem to call TLB's without the B, like Jeff said, a skiploader...it must be a west coast name, because i really never hear that around here.
    My neighbor bought a new Ford 545 skiploader back in the '80's for the farm, and it was a pretty versatile & well used tractor till skidsteers became popular.
    I think the op manual just calls it a Ford Industrial Loader.
    I think the hyd. cyls. on the JD's in the pic, for downpressure on attachments like a boxblade, would be a good feature.
  17. farmerted44
    Nov 17, 2005
    184
    Arizona
    cmon to think of it no. nocats that i have seen.masseys,fords,deeres,case,newhollands, basically tractor manufacturers.
    it is an overused term in arizona (imo) the guys at work even refer to our Cat IT24 as a skip loader. i ask em what do you call it when we have the forks on it?a skiplift? and they say i am a smartass. lol......
    i generally refer to a tractor that the rear wheels are larger than the front, w/bucket in front and gannon or box scraper in rear as a skiploader.
  18. Tigerotor77W
    Tigerotor77W Senior Member
    Nov 1, 2004
    1,014
    Engineer
    Michigan
  19. farmerted44
    Nov 17, 2005
    184
    Arizona
  20. itsgottobegreen
    itsgottobegreen Well-Known Member
    Nov 1, 2005
    180
    Maryland
    I was told they are called a landscape loader. The only one I saw was one that belonged to a paving contractor and it was sold at his going out of business auction for $18,900 something. I believe it was a JD 310 size 1995ish it was 4x4. Had a huge boxscraper on it that had hydraulic rippers.
