I don't have the service manual but you may find this thread informative. -----> https://www.heavyequipmentforums.com/showthread.php?35719-CASE-580F-yes-580-FHi , i am searching for a service manual for a case 580f. Anyone have one? Thanks a lot!
I can get you the 555e in pdf form
That would be great my fuse box fried i have replaced it but i dont want to connect battery
until i trace wiring.
glentanner@bellsouth.net
Thanks
I'm still looking for a Grove DZ66 Manlift. Doesn't even need to be the exact model, need something which can help understand the wiring and hydraulics. Thru the years I have found nothing
Are you sure it's not a MZ66?
Think your right, its MZ66. Probably should post in the manlift forum, would get more views. Been looking thru the threads it appears the grove manlift manuals cost a lot if they can be found and are useless for wiring
Manitowoc owns Grove, Grove man lift parts, sales, and technical service are provided by MinnPar. Grove founder John L Grove created JLC after Grove was sold to Manitowoc.
HI fieldmechanic89 are you able to get 555e in pdfI can get you the 555e in pdf form
Leaky backhoe here,
Looking for wiring diagram for a 1979 Case 580D Backhoe. I think the yr is correct. Anything and everything. Solenoid clicks and that's it. Battery good, Solenoid good, Starter good. Borrowed it to a friend a few yrs back and he broke the key off in the ignition. It has had starting problems and flickering lights ever since. Finally wont start. Luckily it died in my shed after the 1st snowstorm. When I took the dashboard off I realized he snipped off wires and basically did a rig job. My goal is to get it to start again and have working lights. A bonus would be to trace every wire and and find out what the snipped ones just hanging around are for. any help would be appreciated. I must say I love reading on this site and im learning on the go. Im mechanically good with cars but my weakness is understanding electrical systems. Im thinking the ignition switch is hooked up incorrect to start. Thanks
