I'm sure if the trailer could talk it'd scare the hell out of you. My uncle used to get machinery loads from the outfit that had it before me. Said that it had a flip on it just about all the time, and more than once was hooked to a jeep.I wonder if it was overloaded enough to bend the pin, and what part that would have played in the series of events.
Yeah, in three weeks. It took XL 8 hrs. to get a blueprint to the dealer so we knew for sure what size it should be. 3 15/16". What an oddball. So, my machine shop is building one. Whatever they're using it comes oversize and they will turn it down to proper size. Drill the bolt holes in the ends for the lock collars. $850. Thought that is pretty reasonable. It's 64" long. And yes, I will be installing grease fittings in the pin bosses.
That used to be the way with shafting, all the raw material came rough, so a 4" rough piece of stock trued out to 3-15/16, about a 30 thousandths cut and polish it in.
That's what they're using Digger Doug. 4140.Eggzactly....probably 4140-ht, tough enough, but at Rockwell Rc28-30 still machinable, and not going to shatter.
It better. What are your thoughts on making a grease groove around the inside? I have a deburring bit that looks like a BB on the end.Would I be correct in assuming it'll take grease this time..?
YA BUDDY. :beerchug Now if I could just find someone that will chip in for the $2000 bill to cut the old pin out. The guy was all smart@$$ when I called him, says "No problem, I'll blow them right out with the air arc." I said, "They are about 5-6" long, 4" in diameter." NO PROBLEM. Took him all day, 9 hrs, ended up cutting two with the torch.I think you're golden.... I would bet the trick is to keep a grease gun in the gooseneck, give them all a shot when you have it disconnected so there's no load at all on the pin?
The answer for long large diameter pins is always the good old thermic lance ......I've done pins with an air arc, it's murder after the first inch. The air stream flows down alongside the carbon rod, it's designed to go sideways, not straight in.
The piercing setups work because the air or oxy stream is in the center, you can work it right on through.
Mag drill might have been a better bet, in 20/20 hindsight, drill it through, then drill it bigger, then use the biggest cutting torch tip you can get and blow it on out. After a bit you could probably let it cool and it would shrink and knock right out. File that for the next poor sod that has to do this.
So North Dakota qualifies as the bush then..?Agreed. Sometimes in the bush though, you gotta make do with what you got. Still, 9 hours?
It was a judgment call. Hire the work and keep working myself, or stay home and fix it. Moneywise, it was probably a wash, plus I still have my hair and eyeballs.I as going to ask how that went, if you had known that going in you might have been able to burn away at it yourself eh?
At least it is back together and will never be a problem again.
