Well, time to post an update to the creeping Bobcat thread. We have an S185 that we purchased new, has right around 1000 hours on it now. The spools and centering bars have already been replaced twice by dealer during warranty service. Now, it's creeping again, more wear on spools and centering bars. Dag nabit! This is about annoying! Damn Chinese steel! I called my Bobcat dealer and talked to the Service manager. Told Issac what was happening and asked if there was anything we could do to fix this annoying problem. He said "yeah, I'll put together a parts list for ya and fix you up". Our machine has the two piece steel pintle arms, but I suspect if you have the aluminum pintle arms that have these worn spools and bars, these parts may work on them as well.
Safety Warning: Never perform these repairs unless machine is raised of the ground and resting on sufficient stands/blocks with all wheels off ground and free to turn.
While waiting on my go-fer to go get parts, proceeded with removing components. Now this S185, unlike the 753 at beginning of this thread, has a hydraulic driven fan. These components make it really difficult to reach in work on the drive centering plate components, removing the spools would be difficult. So, instead of repairing centering spools with pintle arms attached to drive motors, I opted to remove pintle arms.
Cage the centering spring as shown in post #1 of this thread, remove centering spring/bolt, and remove the centering plate. You now have access to the pintle arms.
Remove the nut that attaches links from drive levers to pintle arm, you have to hold the bolt head from underneath or bolt will turn on this model. Then remove the two 3/8" bolts that attach the pintle arm to the drive pump lever.
Now you simply lift the pintle arm off of the pump shaft lever. Yeah, there's those junk worn centering spools.
Flip the pintle arm over and clamp centering spools in a vise, remove the retainer bolts and remove spools from arm.
Your going to have some wear on the centering bars as well, remove the bolts that mount them and turn them around 180 degrees and you'll have a new surface to work with.
Ok, here are the goodies. Stud mounted cam follower bearings, 4 flanged nuts, 4 thick shim washers, and 8 thin shim washers.
Here's your parts list from Bobcat and todays parts prices per each:
(4) #6673789 cam follower bearing $29.14
(8) #25E17 thin shim washers .98
(4) #6557831 thick shim washer .78 (less than thin washers?)
(4) #98D6 flanged 3/8-24 nut 1.38
Or use a Timken CRSB-14 cam follower bearing from a bearing supplier, appx 17.00 each
