I did remove the engine plus the muffler, rad, oil cooler, Fan housing and a bunch of lines. I have access to the valve. A real pain in the rear.
Took me a while to get the engine out, the exhaust wasn't going to come off the manifold without breaking off a bolt and the pipe was frozen to the muffler, so I had to use a saws-all to cut the stub off the bottom of the muffler. I will weld it back on before I replace everything. I'm also not as strong as I was when I was 60 so I had difficulty moving the mass around.
Thank you for the advice.
