Removing and installing skid steer rubber tracks
Discussion in 'Shop Talk' started by willie59, Nov 8, 2010.
  1. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,695
    Service Manager
    Knoxville TN
    Here's a trick I use to remove and install rubber tracks on skid loaders and crawler dumpers. Rubber tracks on mini excavators are a little different as the steel center bars are made different. Although the rubber tracks on skids are relatively small and not terribly heavy, the tall center bars are a slight obstacle in removing and installing the track at the front idler. There is a simple and easy trick to do this with little effort.
    Support the machine off the ground just enough for center bars to clear bottom rollers and no higher. Open the grease fitting on track adjuster. Now I avoid making messes when possible, and grease from a track adjuster can be a real mess. On this Bobcat T190, the grease release valve was just like a brake bleeder fitting. I simply put a piece of clear vinyl tubing on the fitting and opened the fitting with a crowfoot wrench.
    As grease came out of the tubing, simply let it flow into a cardboard box.
    The track was trashed so I used fork lift to lift track and retract front idler.
    Now find you some steel pipes or solid round bar stock that when fit between track center bars it is just slightly higher than center bars. Place a pipe/bar in every other center bar space, I typically use 4 pieces.
  2. willie59
    Dec 21, 2008
    11,695
    Service Manager
    Knoxville TN
    Now simply start machine and reverse the track. Roll the bars until all four are on the front idler. This raises the center bars clear of the idler.
    I just grabbed the front of the track with a hook on a chain and pulled it off with the forklift. Once you get the idler end off, the rest is pretty easy.
    When you go to put track back on, get it onto the drive sprocket and rear idler, then work the inside of rubber track on the front idler. Put your pipes/bars back in place on bottom of track, roll the track back, then simply push track onto front idler. Roll the track forward and remove the pipes.
  3. RobVG
    RobVG Senior Member
    Jun 21, 2009
    991
    "Fleet Manager" / Mechanic) 13 excavators (1miniKo
    Seattle WA
    That's pretty slick ATCO.
    I had a story to add but I don't want to clutter a great post.
  4. bill5362
    bill5362 Senior Member
    Oct 29, 2007
    353
    I own a excavation company and a rolloff container
    Indiana
    Atco, that is pretty close how we do it with the pipes, then we use a couple of digging bars and pry them off. That is a slick idea on the hose. We have also put down some floor dry or floor sweeping compound under the track to make it slid. Thanks for sharing you ideas.... Bil
  5. Ncso935
    Ncso935 Member
    Jun 26, 2012
    5
    Northeast Florida
    I also like/use the pipe idea. Is that DOM tubing? Or what size / type is that? The only issue that I have is that it is not always strong enough, and sometimes crushes in the process.
  6. willie59
    Dec 21, 2008
    11,695
    Service Manager
    Knoxville TN
    Actually, that material I'm using is blast hole drill rod Ncso935, it doesn't crush. :D
  7. CM1995
    CM1995 Super Moderator
    8,305
    Slick trick Willie using the tubing on the front idler. Similar in concept, I stick a cheater bar between the sprocket and the track and rotate the track forward to compress the idler cylinder instead of using a forklift. However I have struggled with spud bars to slide the track off the front idler, from now on I am using your 3 pipe method to bring the track off the roller. Thanks for posting that, if only I would have seen this back in '10...:rolleyes:
  8. buckfever
    buckfever Senior Member
    Aug 13, 2010
    797
    southwest pa
    I wish I would of gotten pics. of how we just changed ours on our JD332. We pull the plug on the track adj. then run a short chain through the center hole then around the outside of the track. Now you have a loop of chain around the track we then hook the to another chain hanging from our excavator bucket. Pull up on the track and the front idaler moves back. Next we lift the back of the machine and set the back on the two foot bucket then use the machine to pick up the front. This gives you alot of room to work. Now you go back to the loop of chain in the tracks put right infront of sprocket. Pickup on the track while pulling out and back. The track will pop off the sprocket and then it's easy sailing to pull off the rest of the way. When we put the new on back on we use the D-ring on the coupler to work the track on working the front, then the back, then up onto the sproket. We can change them without a hand tool or breaking a sweat. Unfortanatly we've learned this from changing more then a couple of tracks and the damb things aren't cheap.
  9. Coondog
    Coondog Well-Known Member
    Jun 26, 2012
    88
    Texas
    You are right about them not being cheap. We have a small 247B caterpillar skid steer that gets used for everything and a bunch it probably should not be used for. Being a smaller unit the manufacturer did not use the metal inlayed track guides and just went with rubber. Life is much shorter with this setup. We change them a lot and use the same method as atco. Seems to work well on this style too. It needed new idlers the last time we did it. I ordered some from a supplier in new Mexico and they were much cheaper than caterpillar. They were supposed to be the same thing but when they showed they were made out of aluminum. No time to send them back so we installed them. Not a good deal. Original set ran about 5000 hours. These haven't got 1000 on them yet and they are worn out. Not sure about the price per hour.
  10. Ncso935
    Ncso935 Member
    Jun 26, 2012
    5
    Northeast Florida
    Ccondog, we're those aluminum wheels from trackloaderparts.com? I've heard good reviews about their aluminum, which have grease fittings. I have a customer who is very hard on their 247 and am considering trying the aluminum so that they will be able to try the preventative maintenance route for a while.
  11. Coondog
    Jun 26, 2012
    88
    Texas
    Ncso935, Yes they are on that sight. Bair products I believe. Make for sure positive if you do this to let your customer know the installer should not torque the axle nuts to cat specs. And I had to call the manufacturer for their specs. I did not get any in the packaging. I just was not too pleased with the performance of the aluminum myself. Kind of a soft material or the application in my eyes.
  12. wallacet3397
    wallacet3397 New Member
    Jun 26, 2012
    4
    Scotland
    Hi Wullie95
    Great tip thanks, if I had only seen this before the weekend, would have saved a lot of sweat and tears.
  13. crewchief888
    crewchief888 Senior Member
    Feb 2, 2012
    1,437
    NWI
    i'll add a couple of things to willie's ideas.
    i've been using an old excavator bucket pin 3"d or so in place of the multiple pins.
    i raise (and support) the loader arms, once the track is loose, slip a tanker bar ( or pipe) between the inside of the track and the front idler, lift up and use the machine to drive the track forward and peel the track off. continue to run the track forward use leverage to move the track away from the front of the track frame,
    if you then run the track in reverse it will climb up on the sprocket. may take a little prying to move the rear of the track away from the frame, pull the front of the track away from the machine to approx a 45* angle.
    instlalling a new track just reverse the removal
    let the track lay "relaxed" next to the machine on the same (approx) 45*
    i hook a come-a-long to the top edge of the loader arm (and track) and hoist it into place, push it under & around the rear idler and onto the sprocket, start machine and run track forward until it contacts the outer face of the idler.
    i use a smaller prybar through one of the center holes, and hook on the inside of the front idler, and again run the track forward until it installs itself.
    i do t300 tracks in the field, by myself, in under 3 hrs.
    it usually takes me longer to jack up & block the machine, and load everything back up in my truck, than it does to mess with the tracks.
    :drinkup
  14. willie59
    Dec 21, 2008
    11,695
    Service Manager
    Knoxville TN
    You sound too much like me chief, someone will ask "do ya need a hand?"
    Reply..."nope." :D
  15. crewchief888
    Feb 2, 2012
    1,437
    NWI
    exactly !!
    seems like everytime someone tries to help, especially running the track, i end up getting banged up in the process.
    last spring/summer we had a bunch of recalls on track drive motors, one saturday myself and my serv manager removed tracks & drive motors, disassembled the motors, replaced a couple plugs, reinstalled motors and tracks on 4 machines in 6 hrs...
    paid 7 hrs per unit !! :woohoo
    monday am one of our shop mechanics started on machine #5
    he finished in 10 hours :eek: and needed help
    :drinkup
  16. materthegreater
    materthegreater Well-Known Member
    Jul 26, 2012
    47
    VT
    It does help when the machine can run to turn the track! I had to take off a track on a T190 Bobcat without starting it, and it took maybe 1/2 hour. LONG pry bars are helpful :)
  17. materthegreater
    Jul 26, 2012
    47
    VT
    P.S. Atco it looks like those tracks are worn pretty thin! Must have been used on tar a lot?
    The machines I work with usually break a cable in the track before they wear that thin. But we mostly use them in dirt.
    Our mini excavator tracks last about twice as long as the Bobcat tracks.
  18. Nskipper1110
    Nskipper1110 New Member
    Dec 9, 2012
    1
    Greenville, al
    This is awesome!
    Willie, just let me say how grateful I am that you posted this how-to. I was all torn up about how to fix my bobcat t300 that had a leak on the drive motor. I tried and tried to get the track off with pry bars and wenches, but I failed miserably and wasted a bunch of time. S, I decided to google it one night and found your post. I had some inch and a quarter galvenized pipe, so I cut them up into 17inch pieces and arranged them as shown, reversed the track. I was working in tight spaces and by myself, but using a farm jack and a pry bar, I popped the track right off, took the cover off the drive motor hoses and found the broken nipple. Ran and got a new one, replaced it, put everything back together, just like you said, and was done. I did it all in 5 hours, thanks to your great post. Again, thanks for putting this out there.
  19. willie59
    Dec 21, 2008
    11,695
    Service Manager
    Knoxville TN
    Good to hear it was helpful. And welcome to HEF Nskipper1110. :drinkup
  20. JNB
    JNB Senior Member
    Feb 13, 2012
    808
    Flyin' low and rollin' slow...
    North Texas
    Dredging up this thread to give Willie a big THANKS! I never dealt with tracks until this morning and found this thread in a search. My Case had blown an adjuster seal so I replaced the adjuster assembly. The pipe trick works slicker than snot! Thanks again!
    This thread should be a sticky in the skid steer forum.
