Hi antpoo,
You are correct.
Unless the starter motor was engaged for an extraordinary amount of time the starter and its solenoid will be fine.
It will be the small relay near the starter with the 5 terminals which had the fault current applied to the relay contacts.
If you bridge out the two terminals on the right shown in your circuit diagram the starter motor should engage.
Cheers
You are correct.
Cheers
