PT 110 Fault Code
Tones
Ubique
Can someone tell me what the fault code 5826 is? There is nothing in the operator manual about fault codes.
furu
PNW
I looked in my PT110 service manual and it shows all faults as being in somewhat plain English, not in numbers. Now the Perkins Engine fault codes are in numbers but could not find your code for the engine either.
My PT110 has only has 3 faults and they have always come up in English just as the service manual depicts Sorry I can not be of more help.
Post here when you get the answer as I am now interested in the problem for future reference.
Thanks
Tones
Ubique
Thanks for your reply furu. This is a rental machine that the greenies had got at it before my time. Things have stopped working or never worked since I rented it. Travel speed shows on the puter at the set % but the tracks run flat out, lift arms sag like it's got several thousand hours on it,fuel gauge senser shows high voltage then the gauge disapairs and at 4:55 Friday arvo the engine stops and won't restart and shows this fault code. Rental knocks off at 5 and no weekend service. It's a bugger cause it's only got 260 hours on it.
Tones
Ubique
The numbers are for a failure to regen the DPF apparently
