power steering question
Discussion in 'Tractor/Loader/Backhoes' started by TheOldMan, Apr 25, 2012.
  1. TheOldMan
    TheOldMan Senior Member
    Apr 20, 2011
    273
    retired
    North East Florida
    Changed the last of the filters on the 580C (power steering) and as per the svc manual, tried to turn the wheel lock to lock to remove air etc. Can't go lock to lock with the wheels on the ground. Pick front up with the bucket, and lock to lock with one finger. Back on the ground, about half throw. Drives just like it used to, ample throw to maneuver. Never tried lock to lock before. Is this something to worry about, or just leave it alone?
  2. alrman
    alrman Senior Member
    Jun 20, 2009
    1,970
    QLD Australia
    Not 100% sure of what you are asking - with the wheels on the ground, the steering has power assist & wont come to a stop at full lock? You can keep turning the wheel?
  3. TheOldMan
    Apr 20, 2011
    273
    retired
    North East Florida
    No, the power steering works fine with the wheels off the ground - lock to kock. with the weight on the ground you can turn it about half as far as it whould go, in either direction, and that's all. Like it just doesn't have enough power to go any further. Drives ok, I guess because you never turn it that hard. Probably be ok, I don't think it will ever go off the farm while I own it.
  4. alrman
    Jun 20, 2009
    1,970
    QLD Australia
    Could be a bit of a problem with a full bucket of dirt in the loader.
    Maybe a pressure problem - relief pressure at full lock should be 2000psi. Test point should be at the fitting for the pressure hose at the steering pump.
    Often the relief valve needs a new oring fitted to it.
    Be sure the king pins are OK.
  5. TheOldMan
    Apr 20, 2011
    273
    retired
    North East Florida
    I thought i answered this, but don't find it here - if this is a double post, I apologize. I changed the front tires when I brought this machine home, and I couldn't get much mocement up and down with a bar under the tire, so think the king pins are in pretty good shape. Need to buy a tee to use on the outlet hose to hookup a gauge, then I'll look at pressures.
  6. sbarrett
    sbarrett Well-Known Member
    Feb 17, 2011
    97
    engine builder ,machinist
    georgia
    not a case owner i have a john deere 310a,was just reading this post and was wondering if when the wheels are off the ground,maybe the steering does not contact the steering stops and allows for more travel ,like i said,not butting in,but just had a thought.
