Plasma Cutter?
Discussion in 'Agricultural Equipment' started by Danny B, Sep 23, 2009.
  1. Danny B
    Danny B Active Member
    Jun 29, 2008
    42
    Checotah, OK
    We are considering purchasing a plasma cutter to use on the farm. We have steel pipe for fence building and need to finish one corral and start another. I was hoping for advice/info on what you have used, good or bad.
    Thanks.
  2. bill5362
    bill5362 Senior Member
    Oct 29, 2007
    353
    I own a excavation company and a rolloff container
    Indiana
    I have a ESAB 1125 and it is a beast, had a thermal dynamics and I didn't like it much, it used a lot of consumables and had to cool down short duty cycle. I have never had my ESAB kick out of it's duty cycle, used mine to day and it sliced through 3/4" steel for about 5 hours, only used one torch tip, and cut there was a lot of heat. Hope this helps here is the link
    http://products.esabna.com/EN/home/...nual_powercut®_1300_plasmarc™_cutting_package
  3. Feed Bunk
    Feed Bunk Active Member
    Dec 19, 2008
    39
    NW MO
    I wouldnt want one to build coral with unless I was close to a shop. Scince they need electricity and an air compressor going all the time. We had an esap in school and it worked pretty slick. Out of curiostity our you using pre fab pannels?
  4. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,427
    Service Manager
    Knoxville TN
    I can see where a plasma cutter would be useful on a farm, but I'm trying to figure out cutting pipe with it. Why not a pipe cutter? Or even a portable band saw? :cool2
  5. powerjoke
    powerjoke Senior Member
    Aug 2, 2009
    1,125
    owner/operator/estimator/mechanic/grunt/ditchdigge
    Missouri
    i have a 75amp miller, and use a oxy/accetelyne torch 10times more than the plasma, if your not making cuts in sheet steel often dont waste your money IMO.
    Forgot to ad, there is no "plunge" cuts with a plasma like there is a torch in heavy steel, it just burns up extremely expensive consumables
    Pj
  6. powerjoke
    Aug 2, 2009
    1,125
    Missouri
    alot of guys around here use old guard rails from state surplus, and a plasma would work good for that but, not on pipe.....i am with ATCOEQUIP totally on the portable saw
    Pj
  7. Feed Bunk
    Dec 19, 2008
    39
    NW MO
    I never thought about a band saw, but you could run it off the welder and have a pretty slick cutting machine. I would have to say bandsaws are my favorite way to cut metal besides a torch.
  8. willie59
    Dec 21, 2008
    11,427
    Service Manager
    Knoxville TN
    LoL...I probably use our Milwaukee Porta-Band as much as any power tool we have. It's a handy tool. ;)
  9. roddyo
    roddyo Senior Member
    Mar 24, 2008
    788
    Manipulator of the Planet
    Arkansas
    Probably saddling the pipe.
    Any that we cut off square we just weld the top and bottom, then a few licks with a sledge on the sides before welding it up.
    Anyone using electric cable and sucker rod clips on your pens?
  10. willie59
    Dec 21, 2008
    11,427
    Service Manager
    Knoxville TN
    Yep, I was thinking about that roddyo. But the more I thought about it, to cut the saddle notches and to have the pipe the correct length, just sounded too time consuming. I like your idea better. Cut it to length, flatten the ends with a sledge, and weld it in. Quick and easy. :cool:
  11. roddyo
    Mar 24, 2008
    788
    Arkansas
    Don't ask how long it took to figure that out.:rolleyes:
    Kinda like tryin to weld sucker rod to pipe. It's a lot cheaper to just buy the clips. Plus you don't have to weld on your coral every time you want to get your cows up.:Banghead
  12. willie59
    Dec 21, 2008
    11,427
    Service Manager
    Knoxville TN
    LoL...it would probably be more accurate to say "don't ask how many curse words it took to figure that out". :D
  13. bd797
    bd797 Member
    Oct 6, 2009
    17
    Livermore
    It is very easy to just flatten the ends of the pipes and than weld them to the posts. Time consuming also, not to mention tired arms. I built a little machine out of some scrap flatbar and a hydraulic cylinder that crushes the end of the pipe to the same dimensions evry time. It is run off of either a portable hydraulic unit or off the tractor hydraulics.It is just a matter of cutting everything first, doing the crushing and then welding. It just separates out all of the steps so you dont have equipment spread all over the shop. I would post pictures but I dont have any at the moment. If you're interested, I can do so. That little unit saves me large amounts of time when I'm building panels.
  14. Danny B
    Jun 29, 2008
    42
    Checotah, OK
    Sorry it took a while to get back. Yes saddle cuts is what I'm doing. Getting a clean fitting cut with torch is a challenge. Thought plasma would do better job. However, I do have to make several plunge starts. The demonstration I have seen at the Tulsa Farm Show was so damn fast. I think I like the thought about flattening the ends. Don't want to start in middle of my job. Will suggest that to son when we start on his. Did look at place where I get my O2. They had Hypertherm 35 for about $1500. Should be able to run from my welder. Don't know about my little portable compressor(cfm).
  15. Willis Bushogin
    Willis Bushogin Senior Member
    Nov 7, 2007
    855
    owner
    NC
    cutting
    I have a TD50 and I love it, but for pipe I would use (as suggested) band saw/porta saw. My thought would be a metal chop saw, they are fast.
  16. guest
    guest Well-Known Member
    Apr 13, 2007
    48
    Texas
    I use a metal chop saw also very quick and you can cut any angle you need. I also bought a jig that clamps on pipe to cut saddles with torch it is specific for the size of pipe you use. These work great better than marking with soapstone making several cuts and still not fit. Got it a local welding supply.
  17. OneWelder
    OneWelder Senior Member
    Apr 12, 2007
    483
    Derry, New Hampshire
    Use with Any Drill Motor, Hand Held or Drill Press
    Create Any Angle Saddle Notch on Pipe for Weld Fit-Up
    Uses Standard Hole Saw Blades up to 2.5"
    Compound Angle Adjustment up to 60 Degrees
    Chrome Plated Frame
    Easy to Read Angle Scale
    Long Life Bronze Bearing
    Holds up to 2" Pipe
    Weight 12 lbs
    Part # Description Price Buy Shipping **
    SP PIPE Pipe Notcher $62.99
    $10.00 **
    ** Shipping Quote Via Fed Ex Ground Anywhere in the Contiguous 48 States
    Outside of this area additional shipping fees are required and you will be notified
    upon receipt of order. If you would like a quote prior to ordering call our office
    at 1-800-391-5419 and we will be happy to calculate shipping options.
    Or if I had ad a lot to do I would look into one for a Ironworker such as Scotchman, Piranha- these notchers would work in any press and would be very quick
  18. stock
    stock Senior Member
    Aug 4, 2008
    2,017
    We have moved on and now were lost....
    Eire
    Well for notching pipe on a farm for fence repair maybe one of these,
  19. Karl Robbers
    Karl Robbers Well-Known Member
    Aug 12, 2011
    157
    To be honest I would not even contemplate a plasma for your application. A torch will give far better results and you would have to do a lot of cutting to balance the cost of the plasma against your gas costs.
    Plasmas demand good clean, dry air and small compressors are not good at supplying this because they work too hard, not allowing enough time for the air to cool and moisture to condense. You will notice that your consumable life will be pretty miserable if you use air with much moisture content.
    A plasma will not handle rust or other contaminants as well as Oxy Fuel gas cutting, nor will the cut quality be as good other than on thinner materials. What they can do is handle non ferrous metals and stainless steel. If you don't have this need I would not bother.
    I use plasmas regularly and to be honest I have yet to find a more contankerous machine then a plasma cutter and prefer oxy every time if I cut steel over say 5/32".
  20. danielo
    danielo New Member
    Jan 9, 2012
    1
    London
    I agree Karl, I can't fault your advice.
