Pin-on Bucket Mounting Specs
John Shipp
England
forestry contracting
StumpyWally; here are the revised documents: ...the consolidated list of pin-on bucket mounting dimensions (with diagram) in PDF format... [ATTACH said:
161667[/ATTACH]
...& the source Excel spreadsheets in compressed ZIP format (each upload is limited to 100kb, so I had to split it into 3 parts)...
Bumping this up because it is excellent. The pdf link comes up blue on page 4, post 60.
Great job,
John.
StumpyWally
Liv'in the Dream ---------------> in Ballston, NY
PE Civil Eng'r, Computer Sys. Mgr., Retired
Great job,
John.
Thank you much for the kind words...The PDF link in my post #60 works fine for me when I try it...if it still doesn't work for you & you would like a copy, drop me your email & I can send you a copy directly.
John Shipp
England
Hi Stumpy,
Works fine in post 60 thanks, just didn't come up right in the quote in my post 64 above.
Cheers mate,
John.
Mulemn
Arkansas
308e2 cr bucket specs
If anyone has any info on the pin-on bucket mounting specs for the following current 80 class (midsize) excavators, please post it (or send it in a PM to me), & I will update the master list & re-post to HEF here:
23.6" (600mm) -wide Steel Tracks
Case CX80C (probably same as Link Belt)
Cat 308E2 CR SB
Hitachi ZX85USB-5 (probably same as John Deere)
Kobelco SK80CS-3E
Komatsu PC88MR-10
Kubota KX080-4
Link Belt 80 X3 (probably same as Case)
John Deere 85G (probably same as Hitachi)
Takeuchi TB290
Volvo ECR88D
17.7" (450mm) -wide Steel Tracks, or Unknown Width
Bobcat E85
Doosan DX85R-3
Komatsu PC88MR-8
Wacker-Neuson 8003
308e2 pin dia 50 mm, between ears 203 mm pin centers 308 mm
DemoLady
Ohio
Demolition company owner
StumpyWally, I know it has been a long time since this post was bumped and updated, but THANKS for what you have in your spreadsheet!!!!
Now my questions---
1) for the CAT235 you have the pins listed as 88.900mm / 3.5in - how precise is this? We are looking to put a concrete processor (listed that it fits on a CAT 235) on a machine that takes 90mm pins - do you think it would fit?
2) We have a Deere 330LC - can you confirm that those are 100 mm pins?
Thanks for any help you can provide!
DemoLady
StumpyWally
Now my questions---
DemoLady
Sorry for the delay in replying...
As for the Cat 235, I don't have any personal knowledge of how precise the dimensions are. As noted in the revision history, those dimensions (for models in blue) came from http://www.flanneryplanthire.com/pin-sizes.php in UK. I merely transcribed them & included them in my list. But do note that the source dimensions are in bold, namely stick pin & link pin diameter = 3.50 inches, bucket width at stick & at link = 385mm, & pin centers = 535mm. The non-bold dimensions are just conversions to the other units. Even so, I would think that the 1.1mm difference in pin sizes you mention will require that some suitable modification be made.
As for the Deere 330LC, I don't even see that in my list...sooo, I don't know if it takes 100mm pins. Maybe some other member can offer some info...??
RayF
Perth Western australia
lineborer/welder
The 235 diggers had imperial sized pins. The JD diggers I have no experience with but believe they are Hitachi's? If that is the case a 100 mm pin would measure 99.9 mm.
The 300 series Cat diggers have bucket pins that are 0.15 under size.eg 100mm is 99.85
StumpyWally
Finally got some time (it's raining again!!), so I updated my lists with some minor additions (see the revision history in the documents), & here they are:
1. The consolidated list of pin-on bucket mounting dimensions (with diagram) in PDF format...
2, 3 & 4. The source Excel spreadsheets in compressed ZIP format (each upload is limited to 100kb, so I had to split it into 3 parts).
  • 1-EXCAVATOR Pin-on Bucket Mounting Dimensions & Diagram .pdf
  • 2-EXCAVATOR Pin-on Bucket Mounting Dimensions A-J.zip
  • 3-EXCAVATOR Pin-on Bucket Mounting Dimensions J-Z.zip
  • 4-EXCAVATOR Pin-on Bucket Mounting Diagram.pdf
webdude
F@RK!!! this spreadsheet is the Shizzle. Been compiling my own list of dimensions slowly over the years. This is awesome!!! All praise to StumpWally!
007
Hi Stumby, Excellent job you have been doing.
Are you interested in mine which is missing on the list?
U25 Kubota
007
My specs came from kubota not measured. U25-3
Pin spacing 139mm
Ear spacing 109mm
Pin Dia 30mm
Can you upload again please with latest.
Cheers
StumpyWally
OK, done...it's too friggin' hot to do anything else...so, at the end of this post are the updated lists as:
2 & 3 The source Excel spreadsheets in compressed ZIP format (each upload is limited to 100kb, so I had to split it into 3 parts).
4. The pin-on bucket diagram in PDF format.
xr4ticlone
TEXAS
Trusted Adviser to the Construction World
Crazy question here...but how hard would it be to make a (I guess macro) that would allow you to put in your machine's info and see what other machines have a workable bucket?
I ask because I have customers with buckets that I have the measurements but it'd be cool if you could put that in and it would bring up all the machines that would fit.
StumpyWally
xr4ticlone...You're welcome to try the macro route, but a simple way is to just electronically search the PDF, or the Excel spreadsheet with the built-in search tool. If in Excel, every time you find a line (a machine), copy that line to the clipboard & paste it into another sheet. In that way you can build a list of compatible machines.
It's a little tedious, but it works.
cps
Ireland
plant mechanic
Hi StumpWally Any updates?
I have a few i could possibly send you if you wanted to ad them?
