scatterfrats
We are not familiar with where to start with diagnosing. The previous owners let things run down quite a bit, but we felt the price was right for our needs so bought it traveling through two states to pick it up. Back to the problem at hand: We checked to see that the input shaft on the front mounted pump was turning: IT WAS. Hyd fluid was low so topped it off! Don't know where to start with checking out the pressure from the pump. With the engine running I pulled the plug on the top of the filter and fluid poured out, but was easily stopped with just a soft thumb pressure. I am NOT familiar with how much pressure there should be or how to check any hydraulic pressure anywhere in the system. Would love to hear from someone with a working knowledge of this machine Thanks in advance.
