OTC 100 Ton Track Pin Press
Chuck O
Omaha NE
Press is a C-Frame field press with a manual pump for sale. Both are new. If anyone is interested I have pictures.
lantraxco
Elsewhen
I can see the bidding war now. $7,500? Wow, they've gone up.
Does it have a set of tooling with it?
I don't like the "C" frame presses any more, prefer the twin tie rod setups, no offense.
Cheers
Chuck O
Omaha NE
Cheers
No it doesnt have any tooling. Can't find what they are going for on the net. What is it worth?
old-iron-habit
Moose Lake, MN
Not to sound offensive but comparing size of the clamp to the pump it appears to be built light to press 100 tons. The old ones I have been around were only 70 tons and were very heavily built in comparison.
Chuck O
Omaha NE
OTC has good quality presses. I've only used OTC presses before and never had trouble pushing out any pin that was stuck tight. Just someones preference
tctractors
Worc U.K.
Its a shame you lads are so distant as I have a Berco cylinder that you can pull F/Drives down with or press out track pins that I don't need any more, it's a 100 ton plus item the trouble is its so heavy I cannot lift the cylinder off the floor, the standard CAT 100 ton and the Big Nozzie 100 ton cylinder that I use regularly I can lift, not wanting to interfere with any sale here but C frames can be a drama, I had 1 let fly on me a few years back so I bought 2 new rods (CAT around the £600-£700 spot) and stick with them, as I don't like the mess in my trousers???
tctractors
theironoracle
PACWEST
OWNER/OPERATOR MOBILE HEAVY EQUIPMENT REPAIR
I have this exact pin press, I don't do a lot of pin pressing but it works very good and never makes me nervous. I really like the threaded rod to take up the slack....TIO
pins
ireland
hi could you forward some pictures of the press if you still have it for sale please.
tctractors
Worc U.K.
pins, if you are looking for a big cylinder to grunt out pins get in touch when you manage to pop over the water, there is a picture of it in the sprocket pulling thing of mine or look under Berco track press.
tctractors
Huffy
Kittanning, pa.
I have a 160 ton otc track press with tooling. It can come with or without electric power unit. I,m slowing down and will part with it. $6500 with power unit or $5000 without. Will not ship, must pickup thanks
Boude
North Dakota
I am interested please let me know if still available .
wade homuth
murphys ca
mechanic
do you still have 160 ton track press
