Okay how do I do this one?
Discussion in 'Cranes' started by crane operator, Apr 10, 2012.
  1. crane operator
    crane operator Senior Member
    Mar 27, 2009
    780
    sw missouri
    Have a 10' diameter, 65' tall water tower. Need to weld a new fill pipe 3" diameter to outside. No problem, crane and manlift and off we go. Problem- we need to paint the inside of the tank where we make the welds at. No inside ladder and only a 2'x2' access hatch on the top. 20 years ago I would have ridden the ball down the access hatch from the top, and painted as I went (and I can't believe I'm old enough to say 20 years ago, considering I used to do stuff like that). Osha today won't even let you use bos'n chairs, and I actually think this is the ideal situation to use one.
    Bright ideas anyone?
    2'x2' custom basket? I know I wouldn't fit in it.
    65' extension ladder?
    Rappelling tripod from the access hatch? I don't know that I would trust the roof of the old tank to hold it.
    Fill the tank with water, throw someone in with a life jacket and paint as we let the water out?
    Call the OSHA man, and ask him if I can't use a bosun chair, how he wants me to do it?
  2. Trashman
    Trashman Well-Known Member
    Jun 9, 2008
    181
    Solid Waste Services Manager for a city in Central
    Mason, Texas
    Cut a an access hole at the base of the tank big enough to get the man lift inside. flange the access hole for later use.
  3. Hard Nocks
    Hard Nocks Member
    Nov 21, 2011
    21
    RT Crane Operator, Former Boom Truck Operator,
    Cold Lake, Alberta, Canada
    If there is any access to inside of the tower, scaffold up the inside, to the 65' height.
  4. Huntoon
    Huntoon Senior Member
    Mar 14, 2012
    265
    Sales Engineer. I design OEM tracked undercarriage
    California
    LoL, take pictures and post please!
  5. DigDug
    DigDug Senior Member
    Dec 11, 2005
    577
    Maine
    WEld on a 6" fill pipe 12" long . Then reach in and paint interior (through 6" hole) where you welded. Then reduce 6" pipe to 3" and cya later wheres my check!
  6. crane operator
    Mar 27, 2009
    780
    sw missouri
    The pipe is welded about 6" off of the tank with steel brackets every 10" or so up the tank. I wanted them to just cut the pipe loose and reuse the brackets, eliminating the need to get inside. But no, they want to weld new brackets to the tank also. Those welds as well as the top welds where the pipe goes in need to be inspected/ painted on the inside of the tank b/c its drinking water. Its only a 10' diameter tank, so I don't see us driving a manlift inside of it. And no- no large opening at the bottom to put scaffold inside, I think it's only a 2' round door. Sorry guys, I don't have any check worthy answers yet.
  7. willie59
    willie59 Super Moderator
    Dec 21, 2008
    11,488
    Service Manager
    Knoxville TN
    Crane op, this is a bit out of my area of expertise, but seems to me, even on a tank project like this, you are not the design engineer, the folks who own the tank would have to have someone do that. And even if they don't have one, if they're going to specify that you can't use the old mounts, must use new ones instead, and go inside tank to paint weld spots, then they must come up with a way (ladder welded to inside of tank or something) for you to do the work that they specify, no? I mean, we ain't born with wings.
  8. 53cummins
    53cummins Well-Known Member
    Jan 18, 2007
    60
    nw pa
    what about an access hole at the bottom as stated before except just big enough to set a small manbasket inside....... drop the ball through the top hatch, hook up the basket do your painting and inspecting, unhook the basket .. ball out top, basket out bottom. and like was said before weld a flange to seal up bottom opening and have it all painted up ...... wheres my check? haha
  9. FSERVICE
    FSERVICE Senior Member
    Apr 3, 2009
    618
    indiana
    i think rapelling down is the only option, 2 foot is not much wiggle room tho. tie the rope around the engeeners ankles &lower him down to inspect the welds, make sure the rope is long enough so he can get to the bottom ;-) lol then drop the rope!!
  10. CM1995
    CM1995 Super Moderator
    8,135
    Very well said. It seems at times we as contractors are put into some "sticky" situations where we are tasked to undertake something that the engineer/designer either left out unintentionally or intentionally. Sometimes these "fuzy" details, IMHO, are left out on purpose or laziness, in order to shift liability to the contractor.:cool2
    I try not to assume any more risk than need be on a project, Architects and Engineers get paid very well for their services and we as contractors should not be doing their job. Just my $.02.
  11. willie59
    Dec 21, 2008
    11,488
    Service Manager
    Knoxville TN
    And...sounds to me the owner is wanting crane op to absorb the cost of performing this "specification" that they have presented.
    They want new mounts, and want weld heat spots inside painted, the cost should be part of the contract.
  12. Dualie
    Dualie Senior Member
    Feb 24, 2007
    1,371
    Nor Cal
    sounds like a change order to me. No possible safe acess solutions....
    sounds like your going to have to weld a ladder to the lid all the way to the bottom. 65' of ladder down through the hole with a safety tie off rope most likely stainless.
  13. Scrub Puller
    Scrub Puller Senior Member
    Mar 29, 2009
    3,397
    Yair . . . Umm, why would the fill pipe go in the top of the tank any way?
    There must be a reason but I can't figure out what.
    Why is this, does anyone know?
    Cheers.
  14. Hard Nocks
    Hard Nocks Member
    Nov 21, 2011
    21
    Tell them they are going to have to lay the tank down... If they don't actually have to do it, the look on their face will be priceless!
  15. Hard Nocks
    Hard Nocks Member
    Nov 21, 2011
    21
    Oh, and as a side note, if there is a 24" man way in the bottom, and the tank is 10' across, they can use tube scaffolding, as long as they have qualified scaffold erectors. If the only man way is the top, well then it would be a lot harder...
  16. Tiny
    Tiny Senior Member
    Jan 24, 2010
    1,164
    Full time grand kid spoiler
    I'm where ever my Kid's need Me
    Need to CYA , who is going to issue the confined space permit . Who is going to provide or even operate the equipment to see is the air is safe . Most water has chlorine ,that may be a problem
  17. 95zIV
    95zIV Senior Member
    Mar 12, 2006
    794
    RR Contractor Super.
    Cincinnati, OH
    With the pipe going in from the top it will create a air gap so there will be no way for a siphon to start. Also, if you put the fill pipe on the bottom and you get a leak in it you could be looking at massive quantities of water trying to/or will be getting out.
  18. Tiny
    Tiny Senior Member
    Jan 24, 2010
    1,164
    That's how it was explained by one water dept employee , Easier on the pumps and once water leaves the pressurized system they don't want a chance that something in a non pressure storage tank could contaminant the entire system
  19. Scrub Puller
    Mar 29, 2009
    3,397
    Yair . . . 95zIV. Those two reasons you mentioned are the only ones that I could bring to mind . . . there are probably other factors at play here but on a normal installation neither of them are legitimate concerns.
    I would suggest that filling into the bottom of the tank with a check (oneway) valve is normally a better design option . . . and a LOT simpler in this case.
    With top fill there are factors of splash and oxygenation and what all but we won't go there
    I have seen a case where a "professionaly" designed system utilised two 90 mill poly pipes to a one hundred thousand gallon installation on top of an escarpment . . . one came out the bottom for delivery and one went in the top to fill???
    We are talking an extra half a mile of 90 mill. pipe for no advantage.
    Cheers.
  20. Scrub Puller
    Mar 29, 2009
    3,397
    Yair . . . oops! Tiny was quicker on the trigger, I was typing while he posted.
    I'll get back about the pump thing later unless some one beats me to it.
    Cheers.
