This is a General Motors two cycle diesel engine built for all tasks & conditions .
If these engines are really that temperamental about the oil type & RPM's they are sure standing the test of time .
I have to agree to a point on this. The Detroits do seem to be able to live under all kinds of conditions, some that I would consider outright abuse!
For many years we ran 8-71's in IR Drill rigs and when started they would go from cold stopped right up to 1,800 rpm in a mater of a couple seconds. There was a hand control that the operator "could" use to manually hold the governor in the low idle position, but as these drill rigs often were up on leveling jacks climbing up to reach the control was too much effort for the operator so 0 to 1,800 was what they did. I would say that 90% of the problems we had with those engines were from eating the dust that was around them all day.
The sickest looking 3-53 we had was a genset that was put in an application way to light for it. Should have been a small Honda 750 watt genset but they used this 3-53 because they had it sitting there. It would sit there running at virtually 0 load for 12 to 16 hours every night and all weekend for months at a time. Despite looking like someone dumped dirty motor oil over it every night it would be ready to go to work the next night. Black mess was from the dripping un-burnt fuel mixed with the exhaust carbon.
Then there was the 12V-71 we had in the last Terex haul truck, that was run on 15W-40 oil for several years and was still running the day it was loaded on the truck after it was sold at auction. I'm sure it had several stuck rings as it did not burn very clean and was down on power, but with good set of batteries it would fire right up on its own anything above 60ºF. It did burn your eyes to drive that truck!
To make a long tail longer, those old Detroits were and still are tough engines but treating them right does do wonders for the way they run! If I had to have an engine I depended on out in the back woods I would take an old Detroit over any "Modern" engine built in the last ten years! The newer ones are better for the environment I'm sure and may use a bit less fuel but one bad wire or sensor and they are dead in the water.
