looneytunes
I have no response from the throttle dial in cab. The screen is showing electrical problem. This was after I welded a crack in the the bell housing where the pump attaches to it. I small fire develop in the corner below the throttle motor and it got the throttle motor harness plug hot and melted insulation on 5 or 6 wires. I spliced and replaced those wires and still no response from dial in cab. All fuses are good and throttle motor didnt get hot and appears to b e in good shape. I noticed one wire that was stiff and appeared to have got hot thru current and pretty sure it was a ground wire. I am wondering if it smoked the throttle driver in cab. Any help would be greatly appreciated. Jeff
