i used to work at a new holland dealership. you need a special cab jack to jack the cabs over. the jack is similar to rachet binder. it also requires special brackets that mount on the top left cab side screen and at the lower frame where the left loader frame rests. you would have to remove both fenders and the 1/2" bolts at the rear of the cab where it mounts to the frame, and one of the from bolts where the cab bolts to the frame. the whole boom comes foward to. new holland was really thinking when the designed this, tons of access, but it sucks when you need to special tooling to do so i've never seen anyone do without it. good luck
