Randy Krieg
- Joined
- Nov 1, 2007
- Messages
- 260
- Location
- Arizona
- Occupation
- Test Pilot/Operator @ Caterpillar's Tucson Proving
Absolutely! I think it’s a little easier on the smaller machines and much easier with the standard length moldboard; 12 foot in your case. The best way to do this is go out by yourself and pratice this. Years ago I thought about it for a long time before I tried it. I went out to the machine on a Sunday all alone and tried it. I got in and out of the cab several times looking at the clearance in areas that I simply could not see from a seated position. You can’t see that front tire from in the cab, the DCM is totally blocking your view when it's rolling up beside the machine. When I had the DCM in the proper position to clear I would get back in the cab and look at the angle of certain components and get some delta points to line up on. You also can’t see the end of the moldboard that’s going under the step and frame no matter how far you lean, but if know what the angles look like from in the cab you’ll know right where the end of the moldboard is at even though you can’t see it. Provide you have set everything up right at the start, anchor in the proper bolt holes, sideshifted all the way etc. etc. If you’ve missed setting up just one step wrong you’ll tear something up. Copy and paste my previous thread and follow it, you can’t go wrong. Just be sure to get in and out of the cab every few inches of movement and check clearances. Then get back in the seat and look at the angles and position. Everyone that watches me do this now shakes their head, but I’ve done it thousands of times over the years, I do it nearly every night when I park the machine just so we can clean and grease the front circle teeth. It’s like anything we do with a motor grader, the more we do it the better we get.
Be sure your hose tray is not bent up or the arms will hang up on the circle pinion when it’s at about 170 degrees, this is really important on the 16G,H & M because they have a lower bearing support casting, which is under the pinion. If the machine has slope control or automatics you have to be sure there is enough slack in the cable or you’ll tear it in half!!!!!
Regards, Randy
Regards, Randy
