The spike in Lead was a couple of years ago. Do you have access to the repair history? Maybe it had new bearings rolled in after. Note the spike in Silicon on the following sample. That usually indicates dirt but can also be caused by gasket sealer following a repair. Or it could have just been an anomaly caused by bad sampling technique.
The Iron is consistently higher than I like to see but then the oil change intervals are pretty long.
I don't see anything to make you run away just yet. I would try and get its repair history and take another up to date sample to see if the trends are continuing. If you do end up buying it, stick to a 250hr oil change interval to get that Iron trending a bit lower.
