Countryboy
- Joined
- Jun 8, 2006
- Messages
- 3,276
- Location
- Georgia
- Occupation
- Load Out Tech. / Heavy Equipment Operator / Locomo
Welcome to Heavy Equipment Forums hmover! :drinkup
"The 580G was manufactures specifically for the European market. A few made it over here but they do not have the same parts as their North American counterparts. That had the David Brown Engine and the International farm tractor rear end."
Elast - This is very interesting and thank you for unravelling a bit more of the mystery! Can you tell me (a novice when it comes to plant & large machinery) a bit more about the 'rear end' - do you mean the torque and shuttle and final drive? What is the 'International farm tractor' sorry if it's a dumb question but it will help me.
Welcome to Heavy Equipment Forums Elast! :drinkup
Thanks for the reply. You sure are a friendly bunch here.
It's a standard hoe.
At this point I want to avoid having 7 cylinders off the machine at one time and the parts supplier is 1 hour away. So I'm a little confused on the best way to proceed.
I'm wondering if there aren't any tricks to deal with the fluid to minimize loss. Like maybe disconnect one side of the ram and run it one way to put all the fluid into one side and then disconnect one hose and pull the piston back out to push the fluid into the reservoir. Will that work in real life?
