Hello All
I have a Linde H25D-03 forklift with a Perkins 903.27 engine in it. Recently for around ten minutes after starting the engine it is slow or non responsive to accelerator changes and has at times idled down so low it stalls. At first I thought it might be the hydraulic throttle from the transmission but I bypassed that by moving the throttle linkage directly and the engine did not respond.
Does the 903.27 have a mechanical governor that could be causing problems or is it an electronic governor?
Once the symptoms disappear after about ten minutes (sometimes more sometimes less) they do not reappear until the engine is restarted the next day. It does seem to be lasting longer and longer.
Parts manual only shows the injector pump as a unit and not whats inside. Part number for the pump is UFK4A444. I think the pump model is DP200.
Thanks
Phil
Thanks
Phil
