Lighting
Discussion in 'Compact Excavators' started by Farmtruck, Jun 1, 2016.
  1. Farmtruck
    Farmtruck Active Member
    May 31, 2016
    32
    Ct
    Has anyone upgraded the lighting on there machine. Possibly to LED. If not thoughts????? Thanks
  2. walkerv
    walkerv Senior Member
    Jan 22, 2016
    353
    wingate nc
    Our new D8T landfill dozer came with all LED lighting on it. the old D8R doesnt hold a candle to how it lights up the area around the machine
  3. fast_st
    fast_st Senior Member
    Dec 1, 2010
    975
    IT systems admin
    Mass
    Heya Farmtruck, I will say that the econo priced LED's even the 2x3 and 2x6 rectangular led lamps really do a great job at lighting up stuff that's up close. Nice bright diffused light, they don't have a pattern like a true 'tractor' lamp but they work pretty good in the dark. The aluminum housing on the 7" light has taken a few heavy branches and no failures yet.
  4. murfdog
    murfdog Active Member
    Apr 8, 2013
    28
    montana
    I put LED's on my 60 and 135, much brighter, I really like the aluminum housings. I think the stock plastic housed lights come with stick bulls eye's on them from the factory
  5. 580bruce
    580bruce Well-Known Member
    Oct 25, 2006
    197
    entiat wa
    Look up LED worklights on amazon. I put some 5 inch wide ones on my 580. Hope the lesser current draw helps. I want to say they were like 50 bucks for a set of 4. They are awsome.
    tawilson1152 likes this.
  6. pondo
    pondo Well-Known Member
    Mar 24, 2013
    156
    canada
    bobcat w LED resized_1.jpg HI, finally upgraded stock lites on bobcat mini plus one.
    Not sure of exact lumenes, but the replacement on stick is larger, guessing 1700 to 2 000 Lumens and a smaller one on top of cab (600 Lumen)
    Nice White light for working
    Pretty sure the lite on stick over powers cab lite making kindof making it useless.
    It is good up grade, but still want more lite. Looking at adding lite 30" lite bar.
    Choose for size not for Lumens; as that would mount easily across top of cab on existing mounts.
    But 30" would have 31 000 !
    Would that be too bright for guys/labours working infront of machine?
    Anybody else upgrade bobcat mini lites yet. I fished wires up ROPS for cab lites on front, but have not found path for rear facing (on list to do)
    thxs
  7. crazyjncsu
    crazyjncsu Active Member
    May 13, 2015
    36
    Midwest
    Added a 28" led light bar I bought off amazon for $43. Lights up the night and fits perfectly. Really solid. I hope it doesn't get water in it like ones I've heard about. I left the old light installed in case this happens.
  8. Hobbytime
    Hobbytime Senior Member
    Sep 22, 2016
    525
    usa
    The LED lights are great and one light handles a multiple of voltages, so no matter what your running the LED lights will work on it..
  9. treemuncher
    treemuncher Well-Known Member
    Dec 31, 2006
    95
    eatin' trees, poopin' chips
    West TN
    I put 18 HID bulbs and ballasts into the 9 light fixtures on the Barko. This replaced the original 18 30 watt halogen bulbs that were melting the Lexan covers. No more heat, lots more light. All for under $200 from China.
    I AM a bug God at night!
    LED's or HID's go on all my stuff.
  10. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    649
    s/e Heavy equipment operator
    Western Washington
    Nice!!!! Treemuncher, I am of a similar opinion... you can never have too much light :)
    Put couple of 50watt leds and a 24" led bar light on our hitachi 120 made a night and day difference from the stock lights.
  11. pondo
    Mar 24, 2013
    156
    canada
    Yes from cab more light is always better, but at some point laborers will be blinded looking back at operator??
    Crazyjncsu, do u happen to remember how many lumens your 28" light bar is? Do u have guys working in front of machine at night?
  12. crazyjncsu
    May 13, 2015
    36
    Midwest
  13. pondo
    Mar 24, 2013
    156
    canada
    Thxs Crazyjncsu, I am in Canada... Amazon.ca $357 for similar lite bar by same manufacture :(
  14. f311fr1
    f311fr1 Senior Member
    May 12, 2016
    342
    Middle TN
    Put 4 of the 4" X 6" rectangle lights on the boom and cab of our 304C CR. Now we can work way past dark.
  15. alco
    alco Senior Member
    Apr 7, 2006
    1,243
    here
  16. Nick...
    Nick... Member
    Nov 4, 2015
    10
    Uk
    Put a pair on my ec18 volvo and the differance is astonishing.cheap of amazon too
    Nick...
  17. dieseldave161
    dieseldave161 New Member
    Apr 20, 2017
    1
    CT
    thinking of putting a 20" light bar on the roof of the cab of my new to me kx161-3. anyone make any custom brackets for light bars so you can avoid drilling into the cab?
  18. Tags
    Tags Senior Member
    Feb 19, 2012
    432
    Connecticut
    Couldn't you just use the existing brackets for the cab lights and use a piece of angle iron between them and mount you light bar to the angle iron?
  19. cw4Bray
    cw4Bray Member
    Sep 27, 2017
    17
    SD
    I found some LED lamp's on Amazon. I put them in the dome light on my cabin cruiser. I bought them to save battery power, so I didn't have to run my generator. They worked great initially, while at anchor running on house batteries. Then one day I was running the battery charger with the dome light on, the difference between 12.7 Volts and 14V charging voltage SMOKED all the lamps. Voltage regulators vary from machine to machine. The life expectancy of LED's isn't tens of thousands of hours, it's directly related to voltage. The cost of LED's can't be justified if you are buying them yourself.
    The company added a very powerful aftermarket xenon searchlight on my Bell 407 about 15 years ago, claiming it was a safety issue. It worked great and vastly increased safety. The ability to see where you are going and seeing the wires you are about to hit. About ten years ago we got night vision goggles, (NVG). Then about three years ago we removed the strong xenon lights and replaced them with much lower wattage LED's with less lumens. The justification was with the new (NVG) we didn't need illumination any more. I love the NVG's, they allow you to see the clouds that you can't normally see..... but that's like saying; "now that we have airbags we don't need seat belts anymore". We took two steps forward and one step back.
    Blondie70 likes this.
  20. farmboy555
    farmboy555 Well-Known Member
    Aug 25, 2006
    118
    Owner Operator
    KY
    I’ve been thinking about doing the same thing to my excavator’s
    Keep us posted how they hold up
