Have an early 953 (20Z) with a bad hose on the left lift cylinder. Seems almost impossible to replace but I did manage to remove both hoses, but now need to replace both. The issue is how to tighten connections between the hard lines coming from the cylinder and the hose ends. The fuel tank leaves only a couple of inches clearance and although the hard lines are now detached and removed, they must be back in place in order to attach hoses. I can't believe fuel tank has to be removed in order to complete installation and I don't see as how removing the cylinder would help much. Anybody actually replace LEFT lift cylinder hoses before and, if so, suggestions or guidance...
