Cummins ISB
Sometimes while working the excavator with auto idle on it will suddenly idle down. Then it won't rev up again unless I turn the AI off. There doesn't seem to be a pattern of when it does that except when its hot.
Had the exact same situation with a friends Deere 35D. Started out with by trying the simplest fix and changed out the potentiometer although the original seemed to check out OK. Hope, that wasn't it. Ended up with replacing the controller module and the actuator - $2500 later! should have just done away with the AI and put in a throttle lever and cable like the earlier version 35's
