code54
Machine 2015 KX91-3 (300hrs)
Tonight I was digging and in a little bit of mud. I was moving a large stump around and noticed that when I went to move the machine my right track would not spin. The left would spin and slip but not the right. I went to back up and everything worked as normal. I went up a STEEP hill and both tracks seemed to pull the same and the machine went up it.
I bought the machine used and it seems the tracks never had a ton of power but I really don't have anything to compare it too. I read where people mention the motors are not super strong but I was not sure if I need to have this checked or not. If you take it to Kubota and they test it and it tests fine is that covered under warranty or do they normally charge you?
Thanks
Thanks
