Kubota KX 121-2 thermostat
jw3
Tx
Plumber
Are there any special procedures to burping the air out of the cooling system after changing the thermostat? I have shop manuals on the way, they just haven't arrived yet? I appreciate y'all's info because I am in a jam!!!!
Jlillie2
Williamstown Ma.
Media services
I'd run it with the radiator cap off from it and watch it until the fluid gos by once the stat opens. If it drops ad some more. I had valves (On my takeuchi) that were intended for a heater, as they were on the high side, I opened them a little until I had fluid coming out to make sure it didn't get air bound. I assume that you didn't have to drain the entire machine to replace the thermostat right?
jw3
Tx
Plumber
No sir I didn't have to drain the radiator. I did pretty well what you described. I haven't had to add any more anti freeze as of yet.
Jlillie2
Williamstown Ma.
Media services
I'd say you are fine then, I assume that the tem gauge is showing temperature up to the normal level?
If the gauge was exceptionally low, or reading sporadically, I would suspect an air bind.
I think from the sounds of things that you did it all right.
