Mechanic08
My komatsu PC130-7 suffers from a combination problem, which if arm and boom is raised at the same time, one of them will slow down or stop completely until the another one is raised fully, pressure in pump is normal, engine rpm is normal meanwhile if i disconnect the the pump solenoid the engine doesn't drop. Reducing is ok. Any suggestion?
Thank you.
Thank you.
