Komatsu PC 100 -6 trouble
Discussion in 'Excavators' started by Tracktorsboy, Apr 3, 2010.
  1. Tracktorsboy
    Tracktorsboy Member
    Apr 2, 2010
    17
    Indonesian
    hello .. i just bought a secondhand pc 100-6 excavator year of manufacture in 2005 and had a problem with the E05 could you please help because I do not have the manuals, thanks:Banghead
  2. -3Doc
    -3Doc Well-Known Member
    Jul 29, 2009
    119
    Ticketed HD Mechanic
    British Columbia
    Do you know how to get the codes out of the monitor? E-05 refers to many systems and you must get the fault codes to narrow down the problem. this is a partial list of things that could be wrong.
    Abnormality in fuel control dial input value.
    Abnormality (disconection) in motor drive system.
    Abnormality (short cicuit) in motor system
    Abnormality in feedback potentiometer system.
    Abnormality (short circuit) in battery relay output.
    Abnormality (step-out) in motor
    Hope this helps!:canada
  3. John C.
    John C. Senior Member
    Jun 12, 2007
    4,114
    That code indicates there is a problem in the engine governor motor control system. You can put the system in troubleshooting mode by pressing the button on the back of the monitor panel and the left side travel control button on the bottom left of the front of the panel and holding it until the display shifts to the code display mode. You can cycle through all the codes by holding the button in back and shifting the mode buttons.
    Post the codes you find and we can tell you what they are.
    Good Luck!
  4. -3Doc
    Jul 29, 2009
    119
    British Columbia
    we posted at exactly the same time and same info! We must be on the right track!!:)
  5. John C.
    Jun 12, 2007
    4,114
    Cool,
    How can the guy go wrong with both of us providing the info!
    Thanks for the post.
  6. Chris5500
    Chris5500 Well-Known Member
    Oct 23, 2009
    217
    Plant Mechanic
    E-05 refers to many systems and you must get the fault codes to narrow down the problem. this is a partial list of things that could be wrong:-
    Gee, that makes three of us.
  7. Tracktorsboy
    Tracktorsboy Member
    Apr 2, 2010
    17
    Indonesian
    Thanx all for the post... :)
  8. Tracktorsboy
    Tracktorsboy Member
    Apr 2, 2010
    17
    Indonesian
    Code that comes out of the monitor is E101, and the machine does not want turned on, what happened?
  9. -3Doc
    Jul 29, 2009
    119
    British Columbia
    Here is a list of trouble codes. Hope this helps!:)
  10. Tracktorsboy
    Tracktorsboy Member
    Apr 2, 2010
    17
    Indonesian
    Thanx 3Doc..for the list of trouble codes :)
  11. jey_c
    jey_c Senior Member
    Oct 21, 2010
    257
    france
    sorry guys, but the table isn't readable. what's the E303
  12. dirty4fun
    dirty4fun Senior Member
    Dec 30, 2010
    992
    N. IL
    Jey_c
    Hard to read but looks like it says for error 303 (Disconnection in swing stroke limit solenoid system)
    Good luck!
  13. Sripola
    Sripola Well-Known Member
    Nov 15, 2009
    57
    USA
    Hi Guys,
    Anyone solve their E-05 error codes yet? We have a PC130-6 imported from Europe and have the same error code. Furthermore the machine won't auto accelerate and can't turn it off. The battery bulb is constantly on and also there is a permanent beeping alarm. any help would be much appreciated.
    Cheers
  14. mike69440
    mike69440 Well-Known Member
    Apr 3, 2007
    63
    Engineer
    New Hampshire
    It it like mine there is a diode in the altenator that prevents the starter from engaging with the motor running. It is tied into the starter relay. Komatsu has some strange circuits to deal with.
  15. John C.
    Jun 12, 2007
    4,114
    As I recall the Dash 6 model machines that had the Cummins clone installed worked differently that the ones with the Komatsu engine. The Cummins engine has the four separate valve covers and the Komatsu has a single one.
    There was a diode somewhere that I can't remember that would blow letting current back feed into computer telling it that the engine was already running. The give away was that the low oil pressure alarm was going off even though the engine wasn't running.
    It sounds to me like the starter has been jumped in order to get the engine running and the computers are saying that isn't supposed to happen. You will have to pull the fault codes to see what is going on. If you PM me I can send you the procedure and the codes to give you a starting point. I will be out of town the rest of the week and won't be able to get back to you before the weekend. My feeling is that you have some wiring problems in addition to a diode or two blown.
    There are some knowledgable people on Komatsu excavators on this board so maybe they can help you before I get back.
    Good Luck!
  16. salageanr
    salageanr New Member
    Oct 21, 2013
    2
    Bucharest
    Hello
    How did you manage the problem? Because i have the same one here.
    Where is that diode installed? Please can you give me more details about resoving this problem! My equimpent is an PC138-US2
    Thx
  17. salageanr
    Oct 21, 2013
    2
    Bucharest
    Hello!
    Can you please tell me in detail how did you resolve this problem because i have it now.
    Where can i find the diode that you are speaking of? The escavator is located in top of a mountin and i can`t bring it back to a town, so please help me if you can!
    Thx!
  18. adnane hadir
    adnane hadir New Member
    May 18, 2015
    1
    morocco
    E05
    [I have a komatsu pn 240 nlc 6 I have an errore05
    QUOTE=-3Doc;227402]Here is a list of trouble codes. Hope this helps!:)[/QUOTE]
  19. fixou812
    fixou812 Senior Member
    Dec 17, 2013
    677
    Millwright Equipment Mechanic Welder
    Buffalo NY
    Sometimes if you cant read something (those codes here)
    A printer will still print them out, more better
