Mark Meister
Hello all I figured the forum would be a good place to ask my questions. I just bought a beast of a dozer for clearing about 15 acres of brush and stuff. Its a 1979 Komatsu D 75 S-3 crawler its a 46K lb. beast but my question is when running it the motor lopes up & down not bad but I would like to fix it from doing this. It has a Cummins motor I think its a NTO 202 or 220 at least according to some stats I looked at it is a 6 cyl. 200 horsepower. Its been sitting quite awhile I think the PO has been starting it from time to time but not working it
So I'm wondering does the fuel pump need rebuilt or the governor need to be changed or does it just need run? Another thing it does every once in awhile it will jump out of reverse it won't do in forward gear the PO says it doesn't make a noise it just stops moving and then he just puts it back into gear he think it might be the shifter control valve, when I was running it I couldn't make it do it. So what do you diesel mechanics think? And thank you for anything you can tell me.
Mark
Mark
