kshansen
- Joined
- Mar 11, 2012
- Messages
- 11,165
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
Well I do know the NT380 engines we had in the old M-30 Mack had a "Float Tank" on the side of the frame. Those trucks had the fuel tank mounted across the frame behind the cab. The float tank is very similar to the tank on the back of a toilet. Fuel flows under gravity to inlet to the tank and a valve with a float connected to it operates just like the toilet, when fuel gets to a set point the float lifts up and shuts off the flow of fuel. There is a breather, at least on ours, like you might see on a rear axle to allow air in or out of the tank.
Maybe someone else can say why this set up was used unless it is just a "safety feature" to protect the engine in the event the fuel shut off solenoid did fail or if someone stalled the engine and failed to turn off the key.
The other possibility is if the engine was equipped with mechanical shut off valve, yes they do exist, there is one sitting on the shelf were I worked. Someone could kill the engine using it and then push the shut down cable back in and effectively leave the valve open for days.
